Results 1 to 10 of 20
Thread: Shifter knob question
    The shifter on my monger' 70s is not original to the car and is threaded at the top to accept the knob. Does anyone know which year shifter knobs wear threaded so I can purchase the correct one for the shifter?
    Nov 2006
    S. F. Bay Area
    I think the threaded shifter stopped mid-way through MY 1967 production. The threaded knobs can be elusive.
    Brian
    S Reg #1032
    Nov 2002
    San Dimas, CA
    The parts catalog shows the change from threaded shift knobs to the crush sleeve coming "as of model a" which--I think--was the 1968 model.
    In 1965, Porsche 911s used the same knob as the 356C. Those are easily available but the price is getting up there for a shift knob that won't look right in a 1970 car.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Here you go.
    Early S Registry #235
    rgruppe #111
    Nov 2002
    San Dimas, CA
    Interesting. I have to admit I don't have much personal knowledge of the "newer" 911s.
    I dug out this picture from one of the first tests of the 911S in the January 1967 Car and Driver:
    It shows a spherical knob with no shift pattern. The these seem to be available (901.424.104.01) but the descriptions aren't always too clear about threaded vs. crush spacer versions.
    Jim Alton
    Torrance, CA
    Jul 2011
    Chicago Area
    This might work for you: http://www.stoddard.com/69542419100.html
    Mike Fitton # 2071
    2018 911S Carrera White
    Nov 2002
    San Dimas, CA
    There's also the once ubiquitous AMCO knob which did come in threaded versions:
    A threaded one came up at the Pelican BBS a few months ago and there's always eBay.
    They don't cost $ 3.75 any more.
    Jim Alton
    Torrance, CA
    Quote Originally Posted by NeunElf View Post
    Roughly $25 in 2016 dollars...
    Peter Kane
    '72 911S Targa
    Nov 2002
    San Dimas, CA
    Or, you could get a "correct" gear shift lever. Part # 914.424.016.00. Those are available new and used.
    But, if you replace just the lever, reassembly is a chore. You need a vice and a special tool made from a big, cheap screwdriver.
    Jim Alton
    Torrance, CA
    Can someone confirm the thread pitch for 65-66 shifter/screw-on knob, is it 15 X 1.5 mm?
    thanks
    Quote Originally Posted by Sunbeam47 View Post
    John Schiavone
    Connecticut
