Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Shifter knob question
  1. #11
    Aug 2009
    SF Bay Area
    Quote Originally Posted by NeunElf View Post
    Or, you could get a "correct" gear shift lever. Part # 914.424.016.00. Those are available new and used.
    But, if you replace just the lever, reassembly is a chore. You need a vice and a special tool made from a big, cheap screwdriver.
    Jim
    A 914 shifter (from a 70,71 or 72 only) will work fine but is bent slightly differently.
    Jim
  2. #12
    Sep 2012
    Colorado
    There's also the once ubiquitous AMCO knob which did come in threaded versions:
    A threaded one came up at the Pelican BBS a few months ago and there's always eBay.
    They don't cost $ 3.75 any more.
    I bought one of those Amco shifter knobs NOS and installed it in my '69. Much nicer than the "correct" shifter knob. Changing the shifter knob is perhaps the easiest-to-reverse bit of personalization you can accomplish.
    Rich Spritz
    1959 BMC Huffaker Mk1 Formula Junior racecar
    1967 Porsche 911 racecar
    1969 Porsche 911T
    1970 Winkelmann WDF2 Formula Ford racecar
    1973 Merlyn Mk24 Formula Ford racecar
    2007 Porsche 997C4 cab (totaled by an idiot running a stop sign)
    2014 Porsche 991 TurboS cab
    2019 Cayman GTS (wife's)
  3. #13
    Jul 2011
    Chicago Area
    Quote Originally Posted by raspritz View Post
    I have never seen a steering wheel like that before!
    Mike Fitton # 2071
    2018 911S Carrera White
  4. #14
    Sep 2012
    Colorado
    Quote Originally Posted by mfitton View Post
    This steering wheel has been discussed in a few threads here and elsewhere. It is a bona fide Porsche factory design prototype from the late 1960s that didn’t make the cut; probably 1 of 1. At 40 cm diameter, it feels a bit like driving a bus. Even Porsche made mistakes! For a couple of decades it hung along with another on the wall of a former Porsche factory design engineer as “art”. I’d love to see the other one he had!
    Rich Spritz
    1969 Porsche 911T
  5. #15
    Nov 2002
    San Dimas, CA
    What really strikes me as unusual about that steering wheel is the thickness of the rim. It also lacks the dark stripe of the standard wheel.
    If you think a 400 mm wheel is like driving a bus, the standard wheel is 425 mm and the wheel in my split-windshield microbus is 450 mm.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
  6. #16
    Sep 2012
    Colorado
    Right. No stripe, and the thickness of the wood is 'fat' at 22 mm.
    Rich Spritz
    1969 Porsche 911T
  7. #17
    Quote Originally Posted by John912 View Post
    Can someone confirm the thread pitch for 65-66 shifter/screw-on knob, is it 15 X 1.5 mm?
    John, yes it's 15 x 1.5 mm, the same as a 356 from 1960-65.
    Jon B.
    Vista, CA
  8. #18
    Thanks for providing so much information to this forum Jon
    John Schiavone
    Connecticut
  9. #19
    Feb 2003
    Los Angeles
    PM sent to the OP.
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
  10. #20
    Is there any way to fit a threaded knob to a "crush type" shift lever without threads? Thx
    '67 911 SWT - 500634
