Thread: 72 oil console
    Nov 2008
    Chevy Chase, MD
    72 oil console
    72 oil console. It is not set up for a front oil cooler but I believe that it can be.
    $500
    You can pull the hex plug shown in the picture and the thermostat will work for the 911S circuit with remote cooler. You will need to get the proper adapter to connect to the thermostat. Chuck has them here, http://www.elephantracing.com/oilhan...911adapter.htm
    Best regards,
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Feb 2007
    San Diego
    72s are the easiest year to add an external cooler to, thanks to this neat little part. Another reason that 72 is one of the best years ever made. I think you need to machine the thermostat opening slightly, been a few years since I've done that but it is easy.
