This is an interesting blog post about all sorts of nerdy technical stuff, but most importantly oil tests. Well worth the read.
https://540ratblog.wordpress.com/201...-test-ranking/
For those too lazy to read:
From those failures where I was able to find out what specific oils were used, it turned out that those were oils I had already performed my Engineering Wear Protection Capability tests on. And all those oils had only provided poor wear protection capability, meaning that if they had looked at my test data before using those oils, they would have known in advance that their engines would be at significant risk of failure with those oils. And that is just what happened.
A number of people who have had those failures, and some had repeated failures, have contacted me, asking what they can do to prevent that failure in the future. I tell them to forget all that high zinc nonsense and look at my Wear Protection Ranking List. And to select any high ranking oil there, no matter how much zinc it has, because zinc quantity simply does NOT matter. The only thing that matters regarding wear protection, is the psi value each oil can produce in my testing. The higher the psi value, the better the wear protection. I recommend they use the SAME highly ranked oil for break-in and after break-in. It’s that simple.
WHEN PEOPLE HAVE TAKEN THAT ADVICE, NOT ONE PERSON HAS EVER COME BACK TO ME TO REPORT THAT MY RANKING LIST DID NOT WORK FOR THEM. Since my ranking list has worked in every case to prevent wiped flat tappet lobes and lifters, it can also work for you to provide the best possible wear protection for your engine. My test data is the real deal, it exactly matches real world experience, and it is the best and most complete motor oil comparison data you will ever find anywhere.
And for those people who have been able to use various high zinc oils without having trouble with their flat tappet engines, that only means that the oil they used had enough wear protection capability for the loads their engines saw at that time. It does not mean they were necessarily using a great oil. And it does not provide any information about how much reserve wear protection capability their oil provided, nor how their oil compares to other oils on the market.
But, there are some high zinc oils that do provide excellent wear protection. And you can see which ones they are, by looking at my ranking list below.
