Is the 68 dash top different to the earlier SWB one's.? I am trying to source one for a 68 car and would appreciate some pointers if there are several types.
Thanks in advance.
Dave
Thanks in advance.
Dave
https://www.facebook.com/Beltwerks-139610016684496/
S Registry # 1660
Le Belgique ST build.
http://www.ddk-online.com/phpBB2/vie...p?f=28&t=42628
Dave, As stated above; two piece dash for 68`-only. The flat portion of the dash where the speaker grill is located is a continuous one - piece all the way across the dash! The front part of the dash facing the inner cabin is also of one piece , stretching across the entire car, door to door....cliff,
—Juan Manuel Fangio[48]
”What would PORSCHE do”
Thank you gents. Now i need to try and source a decent core.
S Registry # 1660
I have the speaker piece in excellent condition.
Michael Moenstermann
Osnabrueck - Germany
Early 911S member #1052
'While accelerating the tears of emotion have to flow off horizontally to the ears.'
'Understeer is when you see the tree you are hitting, if you only hear the tree then it was oversteer'.
'You can't treat a car like a human being - a car needs love'. (all Walter Röhrl)
There is a reproduction 68 dash pad (rear portion) available. Check with Carpoint.de
techweenie.com
Thanks for the reply's. It is the front section that will be the "hard to find" part. The rear looks pretty simple to find.
S Registry # 1660
