Results 1 to 7 of 7
Thread: Sportomatic to 915 conversion
    Seasoned Veteran
    Jan 2011
    Northern Ohio
    Question Sportomatic to 915 conversion
    70 E Switching to carburetor engine
    I think I know the basic items needed
    Pedal cluster
    Shifter
    trans mount
    obviously clutch and flywheel
    remove vacuum stuff
    clutch cable
    non sporto oil tank
    questions in mind are:
    is the shift shaft the same or do I need a 915 shaft?
    as far as the clutch cable goes do I need to weld a tube or is it already there?
    what else is needed to make the clutch cable happen? bowden tube? what about by the pedals?
    anything else?
    thanks
    300359
    The clutch tube is usually there but I've seen sporto cars with NO clutch tube. G
    Aug 2009
    SF Bay Area
    Quote Originally Posted by 21window View Post
    Pedal cluster
    Shifter
    trans mount
    remove vacuum stuff
    clutch cable
    non sporto oil tank
    anything else?
    thanks
    pedal cluster cover and carpet piece. (Coupe and Targa are different)
    You don't, necessarily need to change the oil tank.
    Jim
    Seasoned Veteran
    Jan 2011
    Northern Ohio
    Anyone know anything about axles/cv's or output flanges?
    300359
    Aug 2009
    SF Bay Area
    The axles are the same for both transes as long as you use like years. The output flanges can not be interchanged between a 905 sporto and a 915 4 or 5 spd.
    Jim
    Seasoned Veteran
    Jan 2011
    Northern Ohio
    axles on the car now have 4 bolts and 2 dowels. Is there a setup like that for 915 flanges?
    300359
    Aug 2009
    SF Bay Area
    yes, until 1976
