Thread: I have to convert to CDI……
    Oct 2010
    Denmark
    My mind is made up now, have to put my old kettering ignition on my 67 to sleep…. my car runs great on long trip 3-6000 rpm, but 2 episodes with traffic jam
    in Belgien on the way to spa Classic and one today done it. I was stuck in very tuff traffic due to road work, and almost 30 min only run a few meters then stop, …. and then a few meter all on idle 1000 rpm. The plugs dies /totaly black and cannot burn clean. I need more spark
    I`m thinking a package from Kurt from partsklassik with the black coil they have made for the cdi? what do you think
    Is it difficult to fit ?
    I`have seen at tach adapter from sierra madre , any experience with that?
    http://www.sierramadrecollection.com...ls-p24494.html
    thanks
    Lars
    1967 911 Bahama Yellow
    1962 356 TB 6 Slate Grey
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Senior Member eaton's Avatar
    Nov 2009
    DC/Montana
    Read this on Pelican for instructions: http://forums.pelicanparts.com/porsc...electrics.html
    Also, there is a Porsche tach intermediate unit (picture below) that will allow your early tach to work with CDI(at least it did in my case). Maybe Jim at EASY has one?
    I went down this road when I put a 2.2 in my '66 912. I'm pretty much an idiot when it comes to electronics (and much else, I'm sure). So I had Kroon build a harness that allowed me to attach the entire 1970 engine electrical panel to the '66 harness. Works great. Clean. Wasn't cheap. Required me to finally learn how to use a multimeter--a priceless lesson. Of course, simply installing the CDI will be much easier.
    Name:  tach intermediate unit.jpg
    '66 912 with a 2.2
    '62 Lotus Seven S2
    '66 Lotus Elan
    '63 Karmann Ghia convertible
    '76 Alfa Spider
    Restoration newbie.
    Jun 2007
    San Francisco
    I would probably buy it direct: http://www.ashlocktech.com/TACH-ADAPT.html
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
