Thread: Radio faceplate ID help requested
    Hi Guys,
    I have a strange faceplate that at first glance looks like a standard Blaupunkt 60s era faceplate but it just a wee bit different and wont fit a regular 60s Frankfurt . It's the one on the left, the size of the openings are just a bit different, for example the bottom opening being wider(taller) that a standard unit, the one on the right. Does anyone have an idea of the correct use for the one on the left?
    Jul 2011
    Chicago Area
    The one on the left is for the cheaper Blaupunkt radio's that were actually made in Japan. They had larger square push buttons made in 1974 Model 2072.
    Mike Fitton # 2071
    2018 911S Carrera White
    Thanks Mike
