Results 1 to 10 of 12
Thread: CDI wiring help
    Oct 2010
    Denmark
    CDI wiring help
    I need some help with connecting the partsklassik 6500 new CDI + harness and black coil to my stock kettering el panel in my 67.
    Does I still need the exsisting ballast resistor and voltage regulator ?
    what seems so easy for those who knows.. can be a pain for me as my electric knowhow is very limited
    thanks
    Lars
    1967 911 Bahama Yellow
    1962 356 TB 6 Slate Grey
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    You don't need the resistor. The voltage regulator has nothing to do with the ignition, it doesn't change.
    Oct 2010
    Denmark
    thanks Ed
    perhaps you have a wireing diagram to the cdi harness?
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Lars,
    As somebody mentioned, I figured this out years ago:
    Oct 2010
    Denmark
    Thanks John
    sorry to be a pain in the a.... but how does CDI harness from parts klassik translate to this diagram https://www.partsklassik.com/p-946-c...g-harness.aspx
    this diagram says
    Red - power via fulepump +
    Brown - earth via fuelpump
    Blue/yellow to coil 15
    Black to tach wire ?
    what is Coil HV 4 to cap ( distributor) ?
    Lars
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Lars, A B C D
    A= Achtung = 350V CDI output to coil blue/yellow
    B= Batterie +12V red
    C= Contact = Points black
    D= Ground =braid
    This is the way it is for the Bosch CDI, the Partsklassik harness is a replica of the Factory harness. I don't know if the wire colors are the same, you can't tell from the picture. If Kurt is smart he found the identical wire, nothing worse than wires that don't match the Factory because Internet diagnosis impossible.
    Hope this helps! Be careful with electricity.
    Oct 2010
    Denmark
    Kettering:
    I have now taken my stock kettering ignition back to 100% as original , and 100% match to wiring diagram
    the original starting relay is fitter exactly as original 85 ground -30 red /white via terminal block / - 86 yellow to ignition , 87 to balast resistor fuelpump via original wye T- line connector together with ballast resistor
    everything works car runs
    I have fitted the parts Klassik nice system ,everything have been double checked , good ground , all i the corect places acording diagram/ but NO spark??
    red B til 87 on relay
    From original T conector wye red one to 86 with fuel pump ( 2 connections on 86)
    85 to ground
    A blue to coil A
    Ground from cdi box to coil I
    black/purpel to T connector
    ground to engine
    black to points
    can there be an other way through the relay? The original cdi don't have this relay?
    I can't wait to get this nice system to fire….
    LarsName:  IMG1685.jpg
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Senior Member NickP's Avatar
    Mar 2006
    Solana Beach, CA
    I would also suggest taking photos of your parts and installation situation and send them to Kurt. Earlier this week I did this on my twin plug set up and Kurt spent close to an hour helping me out. Kurt's a great guy and very helpful; the system I have wasn't even supplied by Kurt and he still was happy to assist.
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
    Oct 2010
    Denmark
    yes , Kurt have also given me the best service, I will write to him monday , but as I have a long trip tomorrow Sunday I had hoped to run CDI
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Oct 2010
    Denmark
    Kurt got back to me on a saturday morning , fantastic service, seems that my old relay is on the way to the bin.. no power on terminal 87 so made a shortcut to
    +15 wire, IGNITION
    have to find a new relay
    the car runs absolutely fantastic with the CDI , more crisp, smooth, pulling stronger on high revs , revs more easily .
    thanks Kurt
    now we only need to get the tach working.
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
