Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Installing original radio?
    Mar 2005
    I plan to reinstall the period correct radio
    in place of the semi-modern am/fm/mini-
    disc installed by the PO. I considered doing this
    myself until I remembered the nightmare that
    ensued the last time I tried this. Do I need
    a Porsche garage to do this or can a generic
    radio installer do this? I would like to go back to
    the original look while being able to listen to
    FM.
    Don
    1970 911T
    2006 Cayman S
    If you have all the right pieces, this is one of the simplest things to do. Put a few pictures up of what you've got.
    Mar 2005
    Thanks David
    It looks like you have a Frankfurt, but with a Becker faceplate and knobs. I may be mistaken, but that is what it looks like to me. You'll need to source a correct faceplate, side clips and a front cover and rear bracket.
    Maybe a Frankfurt for a Mercedes.
    Jul 2011
    Chicago Area
    Nope that is a Blaupunkt faceplate but normally used for a Mercedes, should still work for you but won't look factory.
    Mike Fitton # 2071
    2018 911S Carrera White
    Mar 2005
    The real issue for me is can I do it myself? I know you
    need a special tool to get the old radio out. And
    I don't know how to do it. So I am probably better
    off having a repair shop do it for me.
    Don
    1970 911T
    2006 Cayman S
    PS: Bought the radio from Oldautoradio and they
    claim it is correct for my 1970 911T.
    Quote Originally Posted by dhopkins View Post
    . . . Bought the radio from Oldautoradio and they
    claim it is correct for my 1970 911T . . .
    Another thread . . .
    http://www.early911sregistry.org/for...-radio-in-dash
    There are a LOT of pics of radio installs, here --- especially of Blaupunkts . . . that show only a small surround to the radio, frequently Frankfurts, too
    What I think would be more interesting to see is how the power-supply used on some of other Blaupunkts are installed/wired --- under/behind the dash. Some of these devices look pretty-d@mn substantial, too, so . . . reeeeaaal curious how all those (heavy) pre-historic electronics get strapped into place --- let alone functioning!
    Aug 2009
    SF Bay Area
    That radio has never been anywhere near a Porsche! It is a European version of a Frankfurt and has some sort of home made retaining clips. I've removed/installed 100s of Blaupunkt radios in Porsches and would have trouble installing that one. Oldautoradio is full of crap.
    Jim
    Mar 2005
    I watched a video on how to remove the old radio
    and install another one. It said to stick a nail file into
    slots. I tried this and had no luck. I guess I will need
    to have an installation guy do it. Though he will be
    used to installing a modern system rather than taking
    out the modern system and putting in an older radio.
    Don
    1970 911T
    2006 Cayman S
    I would not let an "installer" anywhere near your car unless his screwdriver is, as Tom once said, "made of butter."
    As Jim says, that's a euro blaupunkt (you can tell by the push buttons) and it's from a Benz (you can tell by the knobs and the pinstripe face).
    You want one that looks like this (shown at Koenig's classics)
