Results 1 to 10 of 10
Thread: 67S fuel tank
    old softie67S
    Feb 2007
    Sanibel Fl
    67S fuel tank
    The exterior of my tank is in great shape. Issue with clogged idle jets has had me wondering about the condition of the inside. I used a scope today to take a look at the inside of the tank through the fuel filler. The tank has the measles. I am currently weighting my options on trying to restore the tank or replacing it. The Dansk repacement tanks for 65-73 can be had for as little as $300. so cost is not really an issue.
    Are there any physical difference between my original 67' tank and the Dansk replacement that covers 8 model years? Has anyone handled one of these reproductions lately to comment on how faithful they are to the original.
    Tom
    67S soft rear window
    60 356 Cab
    70 914-6 3.2 short stroke twin plug
    05 Audi S4 Cabrio (commuter)
    05 Audi Alroad (family driver)
    Aprilia SR 50R (Sanibel scoot)
    Some people- a couple of years back - had fitment issues with the Dansk tanks (at least on LWB cars). I have no idea if this was a one-off issue with a specific batch of tanks or if the tanks are still manufactured like this.
    http://www.early911sregistry.org/for...-fitment-issue
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    the dansk tank is the later style 68 version with the flat area at the spare wheel bowl
    the breather tube diameter is bigger than on the originalos
    also the breather area is different to the porsche part.
    had some problems with fitting the strainers/filter it was touching the auxillary support(70E) cause the thread was to long.
    had to shorten the thread + alternative fuel line routing.
    for the geeks
    the spare wheel area is a separate welded on part.
    dansk is one pice
    I have the same dilemma, need to replace my original tank, is there a more accurate reproduction tank than the dansk tank
    Thanks Mark
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by Mark111 View Post
    Thanks Mark
    nope......
    old softie67S
    Feb 2007
    Sanibel Fl
    Thanks, that is exactly what I needed to know. I will try to fix my original tank
    Tom
    60 356 Cab
    Dec 2015
    NE Michigan
    I went through this about a year ago on my 69 912. I would do some more research on available tanks, as repairing original is a lot of work and will cost as much or more as a new one. I think Restoration Design makes one. Here is my story:
    http://www.912bbs.org/vb/showthread....stem-Refurbish
    Nov 2014
    Port Orange, FL
    Look up local fuel tank rework shops. I had mine cleaned and recoated on the inside -- worked out very well.
    old softie67S
    Feb 2007
    Sanibel Fl
    Quote Originally Posted by Phil Planck View Post
    The Restoration Design tank is listed for model years 69-73. The Dansk tank is marketed as a 65-73. Moito stated the Dansk is basically a 68 tank. No wonder there may be fitment issues. I seems there may not be an accurate 67 replacement tank being made.
    Tom
    60 356 Cab
    for the geeks
    dansk is one pice
    I am just in the process of attempting to fit a dansk tank whilst my shell is progressing, let's just say it is needing a lot of felting to get it to fit.
    In terms of the flat area on the bowl of the dansk tank, how have people modified the dansk tank so that it looks fully rounded as per an original early 67 tank.
    Mark
