Results 1 to 10 of 11
Thread: Help identify these rear turn indicators
    Could someone help me identify what I have? They look aftermarket to me but I'm not sure. Thank you very much.
    Not aftermarket,,,,they don't have the proper color code wires in them. You got the real thing.
    Thank you Ed. Is there a way to tell what years they are for? I appreciate your comments.
    I can't think of any difference from 69 to the 964.
    Aren't the 84+ housings white inside? They are on my 86, my 87 and my 89 turbo.
    The Netherlands
    Late housings (how late I do not know, 80's?) have a small vent hole in the large middle part of the housing. Can't see it in the third picture because it is turned upside down and that hole is on the bottom half. Later one have different material of shielding on the two separate wires for fog light. No plastic but some sort of impregnated cloth.
    Cees
    At least at one time the white housings only were on ROW cars. Maybe that changed at some point. There was also a reflector difference for the ROW units.
    Aug 2009
    SF Bay Area
    Actually, the housings changed with the 74 and up cars. The difference is shown in the pictures. The 69 thru 73 cars had the drain hole in the middle of the housing. The later car have the drain hole closer to the back. Does it make any difference? Not to me..............................
    Jim
    May 2005
    Oroville, CA
    Pretty sure there is a corresponding hole in the body for the drain tube thingy.
    That was a tell for late fender repairs.
    H
