Very last of my vintage 911 stuff....if you are looking for deals...make me an offer on everything...I might say yes!!!
VIEW ALL PHOTOS HERE: http://s200.photobucket.com/user/vel...?sort=6&page=1
Alot of people want alot of this stuff, but no one seems to want to pay. I take Paypal. I have been a 100% positive feedback Ebayer for over ten years.
It's really simple. Tell me what you want, send me your private email addy, or call me, paypal me, and it's yours. Don't know how else to put it.
GEAR SET(901 5 SPEED 1967 TRANSMISSION I BELIEVE): Most NOS never used. See photos showing no wear: Been in a box for a while.
Description by number: Will sell entire lot for $350.00
1: Needle bearing. Not sure which gear this fits. $$$???
2: Guide sleeve. Not sure which gear this fits. Marked H 72 3. Had a tag reading 1967 911 901. $$$???
3: 3rd gear. 23/29 “N” 901/914 1.26. Marked X CNT on small gear. 4K II N3 on big gear. $95.00
4: SOLD!!!!!!! 19 tooth gear. Marked with H inside a circle IH 3072(the 2 looks like a backwards S)
5: Throwout bearing? Marked BCA 98 $$$???
6: SOLD!!!!!!! 22 tooth gear(complete). Marked with H inside a circle IMA 3AA(the AA is actually two arrows pointing up) $95.00
7: SOLD!!!!!!! 29 tooth gear. Marked 1 H inside a circle 68 II M 4. Also handscribed 3AA. $95.00
8: 28 tooth gear(complete). Marked 10 H inside a circle 69 XI. $95.00
9: SOLD!!!!!!32 tooth gear(complete). Marked 12 H inside a circle 67 IIH 3042
10: 36 teeth on dog ear. Not sure what assy this is. No markings. $95.00
EARLY 911 rear engine mount. VERY NICE!!!! $100
CAMSHAFT BOX: 930.105.101.OR, One side only. 911 2.8L. $50
TRANSMISSION PINION SHAFT BEARINGS(new): OEM PORSCHE. 99911002900old#/91530239906new#. 356 50-59, 911 70-74. $240 These are $340.00 new from Porsche
FAG Trans pinion bearing rear inner. 99905204300. 911 with 915 trans 72-86. $80 These are $120 new on ebay.
TRANSMISSION MAINSHAFT BEARING(new): FAG 99911002500. 911 70-89. $80 These are $150 new on ebay.
DIFFERENTIAL CARRIER BEARING(new): SKF 99905902700. 911 65-89, 912 65-69. $15 These are $27 new on ebay.
TRANSMISSION DOG EARS(new)(2): 911 1972-1983. 3rd, 4th, 5th gears 915. PART NO 901.302.242.03. NEW. $100 each.
TRANSMISSION SYNCRO RINGS(new)(2): 911 1978-1986. 1st Gear. PART NO 915.302.301.06. NEW. $80.00 each.
DIFFERENTIAL OUTPUT SEAL(new)(3): Elring. 99911318340. 911 69-71 with magnesium pressure cast housing. 911 72-86, 912 1969, 924 Turbo 1980, 911 Turbo 1980. $10 each
CRANKSHAFT REAR SEAL(new): Elring. 99911326440old#/99911342641new#. 911 78-86. $10
TRANSMISSION MAINSHAFT SEAL KIT(new, some pieces missing): Elring brand. 99911318240old#/91530091100new#. 911T/E/S 70-73. $25
CAM TOWER REAR RADIAL SEAL RING(new)(4): Elring. 35X47X7. 99911306850. 911 65-73, 912 65-69. $4 each or $10 for set of 4.
DOOR HANDLE RIGHT SIDE: 911. 1974-1989. Not perfect but very nice. All there. 911531061/06200. $100
TURN SIGNAL SWITCH(new): 91161330501. 911 1976-1989, Turbo-1989, 912E. NEW IN BOX!! SWF. $80
VALVE COVERS: One set marked 1973.5 CIS $70.00
INJECTORS USED(6): BOSCH 0280150158. 911 1984-1989 3.2, 944 ex. Turbo and 16V 1985-1988, 924S 1986-1988. $100 for the set.
HEADLIGHT SWITCH USED: No knob. 91161302900. Old part number. 911, 1974-1977, 911T 1976-1977. $20
VDO GAUGES COCKPIT(new)(3): TEMP/PRESSURE/TACH. NEW IN BOXES!! Some small corrosion on two. $20 EACH or $50 for all.
METAL FOG LAMP GUARDS(6): (4) 5 ¾” round. Could stand a respray. $15 EACH. (2) Rectagular 5- ¾”X 3- 7/8” outside. 4-7/8”X 2-7/8”. Could stand a respray. $15 EACH
FUSE COVERS(2): One missing label. $30 EACH
INTERMEDIATE SHAFT: (1) ONE gear 901.105.235.1R.(I believe this fits 1969 and up?) $100
OIL PUMPS (3) 2.2T Scribed 77703. $100
2.4 Marked S.E.F. No drive shaft. $100
2.4 Marked GFG or GTG. $100
OIL THERMOSTATS(2) X1 224 83 000 supposedly 150-160 degrees. 1971-1989?? Used in many 911's. $20 EACH
Note: X1 248 83 000 supposedly 180 degrees.
PISTON RING SET(new): GOETZE 90mm(1.5x 1.75x 4) (1974-1977 911S, Carrera 2.7). Goetze Part Number 08-319800-10. $80
OIL FILTER COPPER GASKETS(6): 1198031B. Victor Reinz. 911 74-77, 914 70-76. $1 each or $10 for the set of 6. Will throw in other copper gaskets in other photo.
CONNECTING RODS: Some complete, some missing bolts or nuts. $100 FOR ALL!!! Shipping will be high due to weight. First group fits 2.4S-2.7S, 72-77
(5) 911.103.105.OR S. JOSB KEX weight group. " " $30 each
(4) 911.103.105.OR S. C 31597 29 weight group. (All complete) " " $20 each
(2) 911.103.105.OR S. 31597 K 34 weight group.(One complete). " " $15 each
(1) 911.103.105.OR S. C 31597 28 weight group.(Complete). " " $15 each
(1) 911.103.105.OR S. 31597 20 U weight group. " " $15 each
(4) 911.103.103.OR S. 23 31033 N weight group. 2.2S 1970-1971 $20 each
(1) 911.103.103.OR S. 26 31033 O weight group. " " $25
(1) 901.103.101.OR S. 5 H 30496 weight group. 2.0S 1965-1969 $30
CAMSHAFT NEED MICROPOLISHING BUT WILL CLEAN UP FINE: 901.105.139.OR (LEFT) 1966 SOLEX!! NON-CENTER OILER $100. 1968 L type, same profile as E.
