This is a 69 Targa with MFI. As I got this car disassembled and I'm more familiar with SWB cars could the LWB experts please identify what each of the holes are for.
Chris
Chris
1970 Irish Green 914-6 w/2.2S
www.reSeeWorks.com
Not sure if this helps but some pics of our 69s before and after we redid that area.
69 911S #1379
65 356 SC #130757
I thought if someone would identify these I could print it off and have the picture on the other side, laminate it, and use it as a guide for LWB restorations.
Chris
www.reSeeWorks.com
I labeled this info in a thread I started on Pelican. See post #23 here:
http://forums.pelicanparts.com/porsc...uel-lines.html
That thread is for a '77, so there are a couple of differences, but it should get you most of the way there.
'73 RoW 911T (project)
'77 911S
Early911SReg #2945
Scott & Frank,
Thanks, Chris
www.reSeeWorks.com
these pictures are from a -78 or later but is still helpful
Bengt
Light Yellow -74
@lagteknik
For a 69;
1. Heater cable
2. Fuel line
3. Fuel line return?
4. Clutch cable
5. Park/Emergency brake cable
6. Accelerator push rod
7. Transmission selector
8. Starter cable
9. Speedo cable
10. Rear brake line
11. Park/Emergency brake cable
12. Heater cable
Tony
I really want to thank you guys. This is a BIG help. I'll print this off and laminate it.
Thanks, Chris
www.reSeeWorks.com
Here's mine, in progress:
Nick Psyllos
S Reg & R Gruppe
1973 Euro 911S
1972 911T to ST
