Results 1 to 9 of 9
Thread: Alternative air filter options
    Mar 2005
    What is the best air filter alternative to the
    factory setup for 1970 911T? The factory setup is hard to
    remove and install and is probably robbing
    some hp.
    Don Hopkins
    1970 911T
    2006 Cayman S
    Stick with the factory filter, it robs no horsepower.
    Jan 2011
    DFW TX
    +1. I reverted to the original air box set up on my T from the rain hat K&N's and it runs much better - fixing a lean acceleration pop that annoyed me.
    Oct 2010
    Florida
    Here's some information on air filters.
    There are really 3 things you want an air filter to do.
    • Provide maximum airflow.
    • Protect against airborne dust particles.
    • Perform efficiently when dirty.
    You want something that can trap 10 micron particles. btw - The air filters the F1 folks use trap 7 microns and still flow efficiently; i.e. No power loss.
    Richard Newton
    Feb 2011
    Northern VA
    Some possibly conflicting info here? One post says it robs no horsepower (my guess this is true up to a certain flow/horsepower level, and then it starts to). While another post says rain hats caused a lean/popping condition. Which by definition would mean that the rain hats were flowing more than the stock setup (which cured it by flowing less and making the mixture more rich). Maybe a better cure in this instance would have been to richen the mixture and make more horsepower?
    Hmmm.
    Mar 2005
    So your saying that a non-stock system using rain hats
    is better?
    Don
    1970 911T
    Senior Member majordad's Avatar
    Dec 2012
    Cork , Ireland
    My 993 RSR.
    and the rest of the car ( which I'm racing this weekend in ht eSpa Summer Classic )
    Jan 2011
    DFW TX
    My theory is that it is not only the quantity of flow, but also its quality. I believe the factory air box flows air better... Maybe that means with less turbulence but not sure.
    Mar 2013
    Surrey, UK
    I would recommend removing the snorkel thing and replacing it with an 3.0 RSR style one. In my opinion it looks much better than the 3rd party replacements.
