FS: A set Hella TTG lights, these are the correct size tungsten bulb Hella TN1-TN2 lights for your early restored Porsche, they are in very good condition $625 shipped to USSV100803.jpgSV100804.jpgSV100805.jpgSV100806.jpgSV100807.jpgSV100808.jpg
These are still for sale
Bump for this Hella TTG lights
Are these the same as 914 fog lights only they have chrome back?
Mike Fitton # 2071
2018 911S Carrera White
Yes, that's correct
Ok, one more question. If you already have below the bumper fogs, how would these be incorporated into wiring and switch?
Mike Fitton # 2071
I really don't know this, maybe the experts on this forum can answer to this question.
Mike, I'd just run a whole separate circuit to a separate switch on these. Easy peasy.
Essentially, but there are
A couple of minor differences in the cases when built to the Porsche spec. Also, the TN1/2 lense is not technically correct for the US Tungsten fog light.
Why add a second set of fogs if you already have the under bumper? Personally I'd add driving lights TTG.
When fogs were mounted under bumper and driving lights added through the grill, the driving lights were often wired with the headlights or, an additional switch (usually the small Bosch) was added
To the dash just right of the clamshell.
Michael
-Dusty 70S Coupe
-S Registry #586
Was the TN1/2 Hella Fog used as an option"Under-Bumper" for the 73 RS?
