Results 1 to 9 of 9
Thread: Tire choice for my Raw build
    Sep 2009
    COPENHAGEN, DENMARK
    Tire choice for my R"aw build
    I need a piece off advice of tire size and recommendations for my swb R"aw build
    the car got R flares in the back
    and I got new "repro" 7R 15" wheels in the back ET 47
    and 6*15 ET 36 in front
    Do I need a spacer in the back !!! would like to fill the arche out to the edge, and give the car a bit of stance
    Marek
    Senior Member joegt3cup's Avatar
    Mar 2004
    Colebrook CT
    Yes I believe a 21mm spacer was used with the 7R wheels on SWB cars.
    Joe Annicelli
    Early 911S Registry #751
    Polo Red/Black 1967 Porsche 911S Coupe "Walter"
    Black/Red 1967 Alfa GTJr. Coupe "Nero"
    Italian Red 1994 Ducati 900SS/SP looks fast standing still
    Italian Red 1957 Gilera 150 Sport
    Ahhhh the sixties... I envision myself one early Saturday morning wearing plaid shorts, black shoes with white socks smoking a cigarette heading to the hardware store to buy a bag of nails.
    SWB cars are an acquired taste however once acquired theirs no turning back.
    Nov 2003
    Santa Monica CA
    What size spacer would be needed if a SWB car had a spacer from the factory already in the back like a 1968 car ? 68 cars got 7mm in the back I believe. This again to fit 7R wheels. Merek-- Look into Avons for tires. I think 215-60's are coming out soon. Chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    Feb 2007
    Cheshire, UK
    The 1968 Sports Purposes booklet lists 27mm spacers (part number 901.352.413.01) for 7" rim on the rear.
    Tim
    Early 911S Registry #1167
    Jul 2003
    Vienna, St. Gallen, Stuttgart
    Marek, where did you get the R flares? Plastic or steel?
    Thanks!
    Keep up the speed!
    Anatol
    '68 911S coupe
    '92 964 RS NGT
    '09 987S Boxster
    May 2005
    Oroville, CA
    For the street, I would use Avon 185/70 and 215/60. You are going need to space them accordingly to your needs because of the fender/tire/your look combo. I would start with 21mm or so and add washers until you have the fitment that you like. Then have the spacers made....or they may be a standard size. Don't forget the spacers for the front also. The 6&7R "kit" from Porsche racing for privateers was 3mm front and 21mm for the rear. Keep in mind this was for different tires and different clearances. You also have to align the wheels before final fitment as the alignment can change the clearance more than 6mm. Good luck and post some photos.
    JMHO
    H
    Sep 2009
    COPENHAGEN, DENMARK
    Thanks guys for the feed back
    I did order some BLOCKLEY TIRES size 185/70 VR 15"
    before you think WTF is that , here is the link to there Web , and I have only heard good stuff about them
    and price wise they are a good deal and they do got THAT vintage look
    there web is www.blockleytyre.com
    the 215/60 will come later, Lee told me , so I can swap the rears on later
    To my luck I am making a full range of spacers at the moment , So I just have to experiment a bit to get the correct look :-)
    Will keep you posted on this and the steel flares asap
    Marek
    Jul 2003
    Marek, I would be interested in correct R steel flares!
    Good luck with your project!
    Keep up the speed!
    Anatol
    '68 911S coupe
    '92 964 RS NGT
    '09 987S Boxster
    There was a recent test by the German magazine auto motor klassik in which they tested the blockley tyre on a 911. They found that it performed relatively poor in the wet, a better choice seems to be the pirelli cn36. Link to the article (german): http://rennlist.com/forums/attachmen...assik-0716.pdf
    Quote Originally Posted by Marek View Post
    To my luck I am making a full range of spacers at the moment , So I just have to experiment a bit to get the correct look :-)o
    Marek
    Peter Stey
    1973 T Coupe with 2.7MFI
    1970 S Targa (sold but not forgotten)
