Results 1 to 7 of 7
Thread: FS: 1973 Carrera RS Tribute/Hotrod – Freshly Built
    SOLD.
    As some of you may have seen, I had this listed for sale last Fall. I took it off the market to do a full engine rebuild, so I'm offering it up again. Here's some details:
    - Started its life as a 1969 911T
    - It’s been driven about 1,100 miles since its restoration/build and has a spectacular, high quality Gulf Orange paint job.
    - Engine: Freshly rebuilt (less than 600 miles since rebuild) 2.7 ltr. twin spark with electronic ignition (Electromotive) and Weber 46 IDA carburetors, 7R Magnesium case, ported heads.
    The rebuild includes: New JE 10.5:1 90mm pistons, replated Nikasil Mahle cylinders,
    new DC40 “Mod-S” Cams, cleaned & inspected heads (rebuilt as necessary), valve job, new valve guides and valve seals, new ARP steel head studs, new ARP connecting rod nuts and bolts, new timing chains, new main bearings, new layshaft bearings, new rod bearings.
    Balanced crankshaft, clutch and flywheel. Estimated at 225 hp. Compression is at 210. Has headers (no heat), Leistritz muffler.
    - Freshly rebuilt 915 Transmission, new Sachs Power Clutch, resurfaced flywheel.
    - 930 Brakes on all 4 corners, 930 suspension and 930 steering rack.
    - Zero Rust
    - Steel flares - rear
    - Large front oil cooler
    - H4 headlights
    - Crack-free dash
    - 15x7 and 15x8 Fuchs (real and freshly restored), new tires
    - New rubber seals (OEM) all around
    - New RS door panels, new Appbiz RS lightweight carpeting, new black headliner
    - New K&N Air Cleaners with Rain Hats
    - New motor mounts, new starter, new battery (single, located in Smuggler’s box), new brake master cylinder, fresh brake fluid, fresh transmission fluid, fresh motor oil and filter, 4 wheel alignment.
    - Radio delete
    - Car is located in NH
    You can see more/larger pics of my RS Tribute here: https://www.dropbox.com/sh/x8awy82wb...sOq6eoDqa?dl=0
    still available.
    to the top.
    Price reduced to $92,500.
    still available.
    Saturday bump.
