Thread: Best place to ground radio?
    Mar 2005
    What is the best and closest place to ground my "new" original radio?
    Don
    1970 911T
    Senior Member csbush's Avatar
    Jan 2009
    San Antonio Texas
    I grounded mine where the support bracket mounts to the chassis at the back of the radio. Close and a good solid ground.
    Chuck
    Early 911S registry #380
    '70S
    '75S
    '96 C4S
    '65 R69S
    Mar 2013
    Surrey, UK
    I grounded mine to the steering wheel, where the horn also grounds.
    Mar 2005
    So I grounded it the same was as the previous radio had
    been ground to a screw in the painted metal panel
    behind the support bar. Once it was connected including
    the ground, the power wire, antenna, and speaker
    wires I found that it did not work. BTW, while I was
    connecting the wires the hot yellow wire touched the metal
    sleeve and there was a short puff of smoke from under
    the dash. I looked under the dash but could see no
    damage. The radio did not work. I contacted the supplier
    and they asked for a photo of the connection. After
    I sent it they said they would exchange it after their
    current Holiday (what holiday?) Now I am waiting.
    Originally I sourced the radio from them because I assumed
    it was more likely the radio would work and that they
    would stand behind their product. I don't think I will
    use them again.
    Don
    1970 911T
