Thread: HELP!!! Does Anyone Have a Good Method for Cleaning Brushed Alumninum Dash Fascia?
    Oct 2009
    Indiana
    Friends,
    I have a '68 with the brushed aluminum dash fascia. Over time, of course, the fascia has acquired some "character marks," which I would like to minimize, if possible.
    Does anyone have a reliable method for restoring the dash fascia?
    All help is appreciated. Thanks, in advance.
    Shift Knob Maker
    Oct 2004
    Marysville, OH
    Unfortunately no. The pieces where anodized originally and really need to be re anodized to be done correctly. They get stripped, polished and anodized. An alternative is to use oven cleaner to strip the old anodize off, fine grit sand and polish. It would be fine if you are prepared to maintain the finish, it will need re-polished occasionally which will not be fun once installed.
    Mark..
    Senior Member 767driver's Avatar
    Oct 2008
    Parkton, MD
    There is a product called Bar Keepers Friend...been around forever...that you might want to try. Comes in an old school shaker can like Comet. May also be available as a liquid. It's cheap and readily available and generally pretty mild. Works well on stainless steel and has lots of household uses.
    Worth a shot!
    Lee Fishpaw
    O Gruppe #20
    Early S Reg #2175
    R Gruppe #714
    '70 914-6
    '88 911
    '85 928S
    '74 260Z
    '74 TR6
    Jan 2007
    North of the GG Bridge
    I have tried several things; green scrubbies, sponge type sanding blocks, cleanser like comet and noting has worked. However, I have never stripped the anodizing off and then tried to finish with one of the above mentioned. Perhaps that would work. The technique of using a light abrasive and working in one direction works on stainless so perhaps after stripping it will work on the dash pieces. The dash pieces like the Targa bars are not a mirror shine but have a directional grain to them.
    Dec 2011
    Monroe, WA
    Good morning Mike.
    If you can't get it corrected to your satisfaction you could always buy a new set if they're still available from Marek Lappok.
    His Email is early911parts@Gmail.com
    I bought a set for my car and it is spot on. You will have to supply your own adhesive.
    Good Luck!
    Peter
    "Fahr drauf, bremsen ist feige!"
    Oct 2009
    Indiana
    i have carefully considered the idea of buying new aluminum, but after acknowledging all of the factors, i think i will clean it as best i can and leave the "character marks." i am a bit conflicted about the decision, but i had previously decided to keep the dash original, using the original switches, gauges, wheel, clamshell, and dash top, etc. i just didn't want to pretend that this was 'new.' i know that is going to sound flakey to some. but it was pretty much the only thing on the car that seemed undisturbed, and it seemed sympathetic to keep it.
    so, i'll clean the aluminum, and re-glue it, and finish everything up the way i got it.
    but thanks to everyone who tried to help.
