Thread: 901 trans on a 7R case possible?
    Hi,
    I know it sounds strange as people normally want to go the other route.
    I plan to build different engine (more peaky -> +4000 rpm) but will stay below 200hp
    It will be based on based on a 2.4T (7R-case).
    I have a fully rebuild and healthy 901 5 speed transmission. I like the dogleg shift pattern
    So question is if I can mate my 901-transmission to a 7R-case?
    Bart
    May 2005
    Oroville, CA
    The mounting is the same but you need to change the flywheel....
    H
    Jun 2013
    lynchburg, Va
    Quote Originally Posted by BartdeBruijn View Post
    Hi,
    Bart
    Have had this combo in my track car since 1992 and it still works fine. 2.7 L RS style engine dyno'd @about 240 HP at flywheel.
    1969 911S Targa
    1970 911S Coupe
    1973 911T w 3.2
    1972 Alfa GTV 2000
    Feb 2007
    Thousand Oaks, CA
    Yes it worked for me. 901/13 trans to a 7r case. Trans, clutch, flywheel, and starter were all original to the car. No problems at all.
    Tom Ching
    69E Burgundy
