Results 1 to 7 of 7
Thread: Source for Black 8mm Spring Washers???
    Senior Member Orbit's Avatar
    Oct 2010
    Jupiter , Florida
    Hello
    I am looking for black 8mm spring washers. Is there a source I can buy them from? Does anybody know what the coating process was used to turn them black in case I have to have them turned black. From a 1970 911, used under M8 x 10 bolt to secure rear brake protection plate.
    PET '70-73 911, 603-00, #06 N 012 241 1 Spring washer, B 8x15, -71 Qty: 6 PCNA List: $0.22
    Stoddard, $0.20
    The hyperlink above contains this picture:
    Hi, in case it helps we have items plated, zinc black to obtain this finish.
    HTH
    Alan
    Sep 2009
    UK
    Alan,
    i assume the item from Porsche is not correct then.?
    Dave
    Hi Dave, in this case I am not exactly sure but there are a lot of items new from Porsche which are the wrong finish. Also we tend to buy items in the 100's and have plated, due to costs.
    HTH
    Alan
    The finish is phosphate. I use to get them fro Metric MultiStansard Corp. G
    Nov 2002
    San Dimas, CA
    Orbit's photo is kind of fuzzy but I think those might be belleville washers.
    JimmyT's photo is a standard spring washer, also called a "wavy washer."
    Belleville washers are usually used to put on real clamping tension. I think they're used for the bolts holding my rear CV joints to the flanges at the transaxle. I'm a little surprised to see them in a standard lockwasher application like brake backing plates. I'd expect to see "wavy washers" there.
    The parts catalg says that 6 B 8 x 15 spring washers help secure the brake backing plate. When the parts catalog says "spring washer" it's usually a "wavy washer."
    Anyway, you can google "belleville washer" and find lots of sources. Alibaba has genuine black Chinese bellevile washers.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
