Results 1 to 7 of 7
Thread: SWB: Orientation of the lock cylinders (ignition and door locks)?
    How was the orientation of the locking cylinders (ignition and door locks) of the SWBs (specifically model year 1968)?
    1) Ignition switch with key bit up and door locks with key bit down (see picture)
    2) Ignition switch with key bit down and door locks with key bit down
    3) Ignition switch with key bit up and door locks with key bit up
    4) Ignition switch with key bit down and door locks with key bit down
    Stefan
    Stefan
    xxxxxxxxxxxxxxxx911 US-delivery 130PS MJ68
    Oct 2009
    Indiana
    we need to stay in touch. i'm doing exactly the same thing. here's what i have found, but please tell me if you found something else.
    i dug out every photo of the doors i could, especially from factory material, as well as the Parts Manual. according to those sources, the door key is as shown in your photo. the key, itself, has the long piece pointed upward; the latch on the back end is pointed upward; and the keyhole is at 12 o'clock.
    on the ignition switch, since you have a locking steering wheel, isn't there only one direction the assembly can be oriented?
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    attached are close ups from #113 so the 64 question should be solved.
    Some 68 reference pics could be helpful...
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
    Jul 2003
    Vienna, St. Gallen, Stuttgart
    Hi Stefan,
    on my 68S the configuration is just like in your picture.
    Keep up the speed!
    Anatol
    '68 911S coupe
    '92 964 RS NGT
    '09 987S Boxster
    Feb 2016
    San Clemente, CA
    as is my 65
    Jul 2014
    bavaria
    copied from the 356 registry
    Geoff Fleming:
    The key should enter the igniton switch with the flat side downward The locking washer goes behind the dash, with the protruding 'ears' entering the two slots on each side of the
    hole. The only item on dash face will be the chromed bezel
    Dick Weiss
    The key's teeth should be upward and appoximately pointing toward 11 o'clock in the OFF possition,the accessory position to the left, and ignition ON to the right. However, the last switch I reinstalled wound up w/the OFF position @ 12 o'clock as the locking tabs were symetrical.
    erwin_loves_polo
    Thanks to Mike, Haul and Anatol!
    The orientations of the SWB locking cylinders are => Ignition switch with key bit up and door locks with key bit down (as shown on the first picture of this thread)!
    I also got this picture, which confirms this orientation of the ignition switch for a 68:
    Stefan
