Thread: Handbrake Lamp Switch Contact Block Adjusment - Screw Driver Access ?
    Nov 2010
    Montana
    Unhappy Handbrake Lamp Switch Contact Block Adjusment - Screw Driver Access ?
    '68 Porsche. Is it possible to gain access to the Fillister Screw for Lamp adjustment without removing the passenger side seat ???
    Or, must U obtain a SPECIAL Tool to get into this tight space between the seats ?
    Thanks for your Advice/Help for DIY Owner.
    right angle screwdriver
    Nov 2010
    Montana
    Due to Slot size in screw head, I resorted to using a flexible metal machinists rule, which worked !
