Thread: Swb front suspension question
    Jul 2012
    Kent, UK
    Hello, I have a swb 1968 'S' four years into restoration it is now going back together, of course four years of moving boxes, has left me short a few bits here a few bits there.
    I am left seeking lower rear front a-arm brackets
    To attach arms
    Can anyone advise?
    Many thanks Rich
    Rich
    68 911S
    mbr. 2393
    Jul 2012
    Kent, UK
    Is this arrangement at the top correct for 1968s ? I'm sure I recall a visible plate on the top of the strut previously?Name:  image.jpeg
    Rich
    68 911S
    mbr. 2393
    The camber plate you have fitted look incorrect.
    I think the part you have fitted is 911.341.018.00 which is from a may 1970 onwards car. This camber plate has a one piece rubber bush.
    The 'give away' is that the diameter of the rubber bush is significantly larder diameter than the support washer which seems to be the correct size for a SWB bush.
    The later camber plate used a larger diameter washer.
    The other significant detail is that the pressed portion of the camber plate is very close to the edge of the hole in the inner wing and this is what prevents the suspension from being correctly adjusted
    The camber plate 901.341.018.01 and every supplier I have found always deliver the wrong part when you use this part number.
    The correct camber plate will allow a much greater range of adjustment.
    I think that with this camber plate fitted you will struggle to do better than obtain 4 degrees of caster rather than the 6.5 degrees that is ideal.
    Unfortunately 910.341.018.01 is NLA.
    We have just completed our first prototype pressing which is still a little rough around the edges but the next version will be better.
    They are pressed from Domex 700MC which is a an extremely high strength steel that is both ductile and weldable.
    This plates are designed to complement the correct rubber bush which we already manufacture.
    Chris,
    Those camber plate look very nice. How much is it for a pair?
    I will be inspecting a '70 911 shortly - How can I tell if the sheetmetal domes of the inner fenders are the early type (pre- May '70) or the later type with lesser caster angle?
    How do you know the change happened in May exactly?
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    68 S camber plate
    Are the non S camber plates or 912 camber plates interchangeable?
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
