Results 1 to 9 of 9
Thread: FS: 70-71 2.2E MFI pump, throttles, stacks, crossbar
    Hi,
    I have a set of 70-71 2.2E MFI pump, throttles, stacks, and crossbar.
    This is a great core setup of all the 2.2E specific parts.
    The pump appears to be in very nice condition. It was stored in a well oiled bag. The inspection covers were removed, it appears well lubricated internally and all pistons were observed to move up and down with rotation and the rack returns smoothly.
    The throttle bodies have minimal corrosion, and no broken mounting tabs. One air bypass screw is broken off.
    The stacks are in good condition, no broken mounting tabs. Missing air box studs.
    Injectors and lines are not included, but injectors are available new and lines are available frequently here and reproductions are also now offered.
    Asking $2600.
    Pics of stacks...
    Hi, Dug -
    I'll take the throttle bodies if you separate your package, thanks!
    - Rob
    Hi Dug,
    If you separate for Rob, I'd be interested in the pump and linkage crossbar.
    Best,
    Anna
    Yes, with takers for the throttles and stacks, I will separate. Sending PMs to Anna and Rob.
    thanks,
    dug
    Can I be second in line for the throttle bodies if the sale falls through with Rob.
    Bump for all parts listed. $2500. I will split if pump is sold, but no deal done yet.
    thanks,
    dug
    Dug -
    You have PM, thanks!
    - Rob
    Dug, I've sent you a PM also
