Thread: Silver Plated Early Original Badge
    Jul 2011
    Chicago Area
    I have seen several hundred original badges and have never seen a silver plated one. Believe me this is an original early smooth back badge, Has the correct pointed shape between the top leg and chest, first and last "T" in Stuttgart has the short stem and you can see the correct bare metal color in the chipped black bar. Anyone ever see one of these?
    Name:  IMG_1682 (640x480).jpg
Size:  92.8 KBName:  IMG_1683 (640x480).jpg
Size:  113.2 KBName:  IMG_1684 (640x479).jpg
    Mike Fitton # 2071
    2018 911S Carrera White
    Feb 2016
    San Clemente, CA
    I have not seen one but the plating will not stick to the enamel. Since it is brass under the chips, this was plated after it was manufactured/enameled and fired.
    Not to hijack, but does anybody have experience with replating the gold on an old badge without damaging the enamel?
    Feb 2016
    San Clemente, CA
    no metals will stick to the enamel. Have it plated and polished and it will be as good as new
    Is the black gasket a separate part number item and still available?
    Doug Dill
    1973 911E Coupe
    PCA #1987109761
    Early 911S Registry #548
    Jan 2006
    Naperville, IL
    Quote Originally Posted by DOUGS73E View Post
    Yes, though it has been superseded. PET Pdf thing lists 901.559.215.20; current number : 7L5-853-611-B
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
