Thread: Help ! Horn wires
    Help ! Horn wires
    Guys see photo of horn form my 73.5 ....
    There are 2 horns but the connectors in rear are same configuration.
    Which one gets the ground and which power?
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Doesn't make a difference
    bob moglia
    '72 E sunroof coupe
    Well, will trust you and also seems to make sense.
    I checked with my meter for continuity and neither post responded to the screws or the bolt for attachment ....but the posts had continuity to each other.
    I had thought one was power and one was ground...?
    Ok will give it a go.
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    I am anything but trustworthy.
    The horn is an electrically isolated circuit.
    Polarity is not an issue.
    bob moglia
    '72 E sunroof coupe
    Apr 2012
    Simi Valley Ca
    The reason for continuity from post to post is that they just go into a wire coil to create a magnet.
    Bob B
    All you guys are brilliant ....thanks for details and tech explanation.
    Next challenge to follow or next several weeks
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
