Thread: 906 engine case vs '69T case
    Jul 2009
    Hamilton, New Zealand
    I am building a 906 spec engine and wondered what the differences were between an original 906 mag case and say a 2.0 '69T case.
    Would a '69T case be ok to build such a beast on or is an aluminum case better? I know the 906 is mag and would love to stay with mag.
    Thanks so much
    '73E RHD
    Jan 2011
    Sunny Southern France
    Lots of differences actually.
    Just to name a few:
    - Additional screw near the oil vent
    - Air fins under case (a little like an aluminum engine)
    - Air fins on sides of the case
    - I think that there is no provision for injection pump support
    - It is sand cast while you mag case is injection cast.
    - Differents machining arroung the distributor port
    and so on, and so on.
    You should go to Armando Serrano's Pbase website. He has some good pictures of an original 906 case, as well as other parts.
    What are you building this engine for?
    Olivier.
    Jul 2009
    Sent you a PM Olivier
    '73E RHD
    Carrera 6 engine, 906. notice the factory tool on the engine.
    Ernie W
    member of Early 911S Registry
    Jul 2003
    Santa Cruz, CA
    Shaawiiiing!
    Michael
    -Dusty 70S Coupe
    -S Registry #586
