Results 1 to 10 of 15
Thread: Early 7 x 15 fuch wheel finish.?
    Sep 2009
    UK
    Does anyone on the board have a close up of the correct finish to the rim of an early, 71/72 fuch 7 x 15 wheel. I am in the process of restoring my two wheels for the front of my ST build.
    I understand that the base of the wheel, and the lower side of the petal should have a rough finish that was left by the lathe machining. How far up the rim did this rough finish extend.?
    Any help or pictures of an original close up would be greatly appreciated.
    Dave
    Dave,
    I have some amateur hires pics of a pair that I used to own. No close-up shots I'm afraid, but maybe you can zoom in and get a closer look. Email on the way.
    Tomas
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    Hi Tomas,
    I m interested, too.
    May you post the pictures?
    Cheers
    Dirk
    Dirk,
    Let me know your email and I will transfer a zipped folder.
    Tomas
    Sep 2009
    UK
    Tomas,
    many thanks for your efforts, file received. Maybe Harvey might chime in.
    Dave
    Jul 2011
    Chicago Area
    Here is a close-up of one of my 7 x 15 that I had on my 914-6. It had a rough finish from the pedals all the way up to the outside lip. The lip had a shinier finish.
    Mike Fitton # 2071
    2018 911S Carrera White
    Sep 2009
    UK
    Thanks Mike. Do you know who restored that wheel.?
    Oct 2010
    Florida
    We need Harvey here.
    Richard Newton
    Jul 2011
    Chicago Area
    Quote Originally Posted by stretch View Post
    No don't know came that way on my car. I can also tell you that the pedal finish matched the outside lip.
    Mike Fitton # 2071
    Thumbs up
    Here's my factory date stamped 3/73 flat 6 spare....
    I believe the factory 7's were the same but of course a little more/wider flat finish on the off-set...
    Hope this helps,
    cm
