Results 1 to 10 of 12
Thread: Vendor Recs Needed for windshield & rubber kit .. for a 1970
    Jul 2014
    SF Bay Area
    Car is a 1970 911 & it is getting a Respray so obviously its rubber time all the way around... And my current front windshield is a cheapie knock off from the 80's that has to go.
    I have Fought with rubber from some vendors in the past and ended up just throwing it out..
    Any and ALL advice greatly appreciated for brand names / vendors..
    Thanks Much!
    TG
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Porsche......save yourself any frustration.
    Tony
    Absolutely,,,,,,,,,,
    International Mercantile is great for light housing drains, spark plug wire hold downs etc, but for the important items like hood seals, engine bay seal, windshield seals, I would only go with Porsche factory stuff.
    1969 911 E #824
    Member dogLeg's Avatar
    Aug 2015
    SF Bay Area
    +1 on glass
    Tim
    1970 911T
    #3257
    Oct 2010
    Florida
    I went with Porsche on the side and back. I wouldn't touch the aftermarket stuff. It never fits properly.
    Name:  911 Rear shelf Repair.jpg
    Richard Newton
    Garage Fires
    The problem is, how do you know it's "Porsche factory stuff"? I've ordered windshield seals from reputable sources packaged with official looking "Porsche" labels only to find out it's garbage. Let's face it, even "Porsche" probably uses a variety of vendors to make this stuff, who then sell it on the aftermarket. Is there a consistent source for buying true-fit windshield seals? Is there a way to look at the seal and know it's right? I tried measuring the cross section and found the good stuff is thicker, around 34-35 mm for SWB 911/912 comes to mind, but can't say for sure. Maybe someone has a sure-fire detection system?
    John Schiavone
    Connecticut
    Senior Member platas's Avatar
    Jun 2005
    Spain/Houston
    John you are very correct, but i have also noticed that factory was does is hold the vendor to a higher standart in quality, i say this, since i have used both, and porsche ones usually have a better fit.
    What i do to make it easier on the installation, is fit it on the windscreen, days before so it molds it self.
    San
    53 Pre A, 65 356
    70 914/6 GT
    65 912, 67 911
    71 911 Targa,72 E Tara, 73 911 Targa
    70 911 S,71 911 S,70 911 T,
    71 911 T, 72 911 E ,73 911 T
    74 911 Coupe
    74 911 Targa
    1972 RennSport Bus
    Early Reg # 771
    We buy from Porsche, World Pac, or Stoddard.
Tags for this Thread
