Thread: Problem engine
    Problem engine
    My 73 makes strange noises (tics) when i brake on the engine. At 1.800-2.000 it somethings hicks when I accelerate. The engine has a perfect compression. Gus rebuilt the mfi pump and I bought new injectors.
    I spoke with a mechanic who claims that the engine gets not enough air??
    Who can confirm this.
    How long have you had the car,,,and how long has it done this.
    I own the car since 2007 and the problem was always there. Now it seems it's worser
    It would be virtually impossible to diagnose a solution for that via computer, I hope your mechanic is good at MFI systems. For starters he's going to need to be able to determine what the running mixture is with an air/fuel ratio analyzer. When a pump is rebuilt it almost always requires minor adjustments when installed.
    Banned
    Nov 2004
    Scottsdale, AZ
    Humor in short supply here.
    Johnson Rod is legit.
