Thread: 69-71 911S mag MFI stacks and throttle bodies 2.0 and 2.2
    Feb 2007
    San Diego
    I have a nice matching pair of 2.2 S stacks part number 911.110.303.1R. These were mounted on a pair of 69S throttle bodies so the holes have been offset drilled for 2.0L throttle bodies. This means they are correct for 70-71 2.2S but will also fit 2.0S with no problems. The nuts and washer will cover the holes and they will function just fine.
    $900 plus shipping
    Next I have a pair of 2.0L 911S throttle bodies. 9011101010R, these have no damage or corrosion, the shafts and butterfly's are excellent, tight and could be used as they are. These have been machined open at the port to cylinder heat to 38mm (stock is 36mm).
    $900 plus shipping
    Both units were working together and could be used together again to get an S going. Because the different years and mods to the throttle bodies I am listing them separate.
    Feb 2007
    San Diego
    bump it up
    Feb 2007
    San Diego
    Let's move these up as see if anyone has interest, I lowered the price listed in the first post
