Thread: WTB: Blaupunkt Frankfurt parts
Hybrid View
    I'am looking for the very thin washers that go on the radio shafts under the mounting nuts.they can either measure,29mm overall diameter with a 11mm inner diameter hole. Or 11 mm overall diameter with a 9mm inner diameter hole.Yes I do know this is a "really" small part.
    Or can anybody tell me where to buy them.
    Thanks David
    Jul 2011
    Chicago Area
    Got a picture you can post and do you know the thickness?
    Mike Fitton # 2071
    2018 911S Carrera White
    Jun 2003
    Toronto
    I used to be a Blaupunkt dealer back in the day, I am pretty sure that I have a plastic drawer full of the washers you are looking for at work. Will check for you tomorrow.
    Rudy
    Rudy,the thickness is only 1mm at the most.Let me know what you have and how much.
    Thanks David
    Jun 2003
    Toronto
    Yep, got a drawer full of Blaupunkt radio shaft washers, but they are different dimensions that you requested. I have attached a pic of what I have, if they will do pm me your info and I'll get a few out to you.
    Rudy
    Thanks Rudy
