Thread: Dimensions of a 65-73 hood
    May 2011
    Chelsea, Québec
    Hi
    Can someone tell me (in inches or cm) the basic dimensions of a 65-73 hood as opposed to a 74 onwards hood? I know the 74 onwards one is shorter, but need the dimensions of the earlier one!
    My car is at the shop (4 hours away) and I need to know!!!
    Thanks in advance
    Stephen
    Member #1616
    Apr 2004
    35,000 ft
    I can tell you it is simply a tiny little bit bigger in every dimension to fit in the back of several cars I tried.
    shorthand fits, longhood doesn't
    May 2011
    Chelsea, Québec
    Cool: that's very helpful...
    Member #1616
    Probably too late but 1335mm overall length, 775mm wide at front and 1195mm wide at the rear
    Jeff Eelkema
    69E (project)
    S Reg #1431
    Aust TYP 901 #132
    May 2011
    Chelsea, Québec
    Thanks, Jeff!
    Quote Originally Posted by jeff eelkema View Post
    Member #1616
