Thread: Valve seal dilemma
    Jul 2008
    near Ottawa, ON,canada
    Valve seal dilemma
    Was inspecting the heads to male sure everything was in spec
    I noticed that whoever worked on it before did not put valve seals on the exhaust valve guide
    I taught the guy who did those before was nuts but more reading indicate its better without
    I know its better to have some on the intake
    But the exhaust yes or no
    now on the road 914-6
    now in the shop for concourse resto 11850275 S SWT
    daily driver B8 S4 stage 2
    I'd do whatever the engine designer says...
    Here's a discussion on the matter. http://forums.pelicanparts.com/911-e...tem-seals.html
    Been doing 911 engines since they started, have always used white teflon guide seals intake and exhaust. Never saw a problem. In an instance where there was a customer complaint of excessive consumption it was discovered previous builder left off the exhaust seals. Let your conscious be your guide. (pun intended)
    Jul 2008
    So in short if you are racing and oil consumption is secondary to valve cooling they are better off and
    If you just want to drive the car as a week end toy pur them on
    Thank you guy the choice is made
