Thread: Help: Unknown Rubber piece in the door
    Mar 2016
    Italy
    Question Help: Unknown Rubber piece in the door
    Hi all,
    I removed the door panel to replace my broken door stop and I 've found this rubber piece floating in the door space of my 1973 T
    Has anyone ever seen this unknown (to me) rubber piece? Can anyone please post a photo of it's original position ?
    Thanks in advance!
    It is simply a rubber "bumper" for the regulator when it bottoms inside the door so that it thuds rather than clanks and with time goes into the metal of the door frame bottom...rust!
    When you get your regulator installed watch where it bottoms when you crank the window all the ay down inside the door and glue the rubber bumper in that position. Viola!
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Mar 2016
    Italy
    Mark,
    thank you for your fast reply.
    I'll follow your suggestions.
    Nov 2010
    Glen Allan, Ontario
    Crappy picture, but here is where it sits. As stated above, basically directly below the point where the cross bars of the regulator meet the door bottom.
    Todd
    1971 911 T Non-Sunroof Coupe
    1984 944 Original Owner
    1989 911 Targa
    Mar 2016
    Italy
    Quote Originally Posted by tholyoak View Post
    Todd
    Todd... we have a different concept of crappy ... your photo is wonderful for me because it allow me to glue the rubber in the right place.
    Thank you
