Thread: 1970-71 911E 2.2 MFI system
    plug-n-play 1970-71 911E 2.2 MFI system. as pictured. (engine not included)
    engine was removed a year ago and has been in dry heated storage since. was running well and strong up to the day it was pulled.
    no discernible play in throttle shafts and all bores look like the pictured ones. includes all MFI items pictured. including cam gear, breather cap, MFI pump, stacks and throttle bodies, velocity stacks, filter console.
    air cleaner housing and bases have some surface rust as pictured, these weren't on the engine when running but are included.
    velocity stacks are un-melted, rare to see.
    will include every nut, bolt and MFI-related doodad upon removal.
    $5500 shipped to lower 48.
    If you would consider splitting I'll have first refusal on the throttle bodies.
    bump......
