Thread: What sequence do you load harness, hoses, cables, etc through the tunnel
    Aug 2010
    Colorado
    For those who have done LWB cars, what is your preferred sequence of running the various parts through the tunnel.
    Also how much hard tubing sticks out front and rear of the tunnel for the fuel lines.
    Chris
    For a 69;
    1. Heater cable
    2. Fuel line
    3. Fuel line return?
    4. Clutch cable
    5. Park/Emergency brake cable
    6. Accelerator push rod
    7. Transmission selector
    8. Starter cable
    9. Speedo cable
    10. Rear brake line
    11. Park/Emergency brake cable
    12. Heater cable
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    I put it all in now while the access is good.
    Aug 2010
    Colorado
    Thanks Ed.
    I've got about half of the parts in there but started wondering if you guys have a particular order you install all this stuff.
    Chris
    www.reSeeWorks.com
    Think that logic would suggest bottom to top and outside to inside as sag of cables/rods etc will inhibit space and access
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
