Results 1 to 9 of 9
Thread: photo of original windown washer spray nozzles
    Senior Member pss's Avatar
    May 2014
    Netherlands
    Could anyone post a photo of an original 1965 one please?
    Cheers, Jacques
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    964 RS clone (one of many)
    964 Targa original Dutch police car (one of 45)
    964 Turbo 3.6 (one of 1450)
    993 S Vesuvio (one of 250)
    Aug 2009
    SF Bay Area
    Quote Originally Posted by pss View Post
    Cheers, Jacques
    They are nothing special. Porsche used the same part from 1963 thru 1973. Readily available at your local Porsche dealer or I can send you a couple, if you want. They are listed with 2 different part numbers. The "901" number comes without the check valve and lists for $29.36. The same part listed under a 914 number comes with the check valve and lists for $19.42.
    Go Figure....................
    Jim
    May 2014
    Netherlands
    Txs Jim. Do they have a double nozzle, 2 spray heads with each 2 outlets? I see several types on offer.
    Are they black or with a chrome cap?
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    Feb 2007
    San Diego
    2 adjustable nozzles per head, 2 heads per car, should have a chrome cap, the have check valve that plugs into each head that may or may not be included with the nozzles you buy.
    Aug 2009
    SF Bay Area
    Here you go..................
    May 2014
    Netherlands
    lovely forum this is, for seemingly easy as well as more difficult questions, always fast.
    Cheers!
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Cheers!
    unfortunatly the current porsche valve is grey unlike the nylon ones used back in the days..
    May 2014
    Netherlands
    not having the nozzles, I do have all the rest of the original 'wiring' ;-)
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    Aug 2009
    SF Bay Area
    Franz
    You are, of course, correct. I think Stout would say we are nit picking, though.
    Ciao
    Jim
