Thread: 2.0L Bosch ignition coil and Bendix pump, which one to buy
    Senior Member pss's Avatar
    May 2014
    Netherlands
    Need a Bosch ignition coil and Bendix fuel pump for my May and March 1965 cars. What is the original thing I should be looking for. Is attached photo showing original? Any advoice where/what to buy is very welcome!
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    964 RS clone (one of many)
    964 Targa original Dutch police car (one of 45)
    964 Turbo 3.6 (one of 1450)
    993 S Vesuvio (one of 250)
    Not sure about the black top on the Bendix although Bendix is right for early 65:
    Somewhere on the forum mention that the current ones available have different fittings to original?
    They are a common pump used in many applications including aircraft and available 6/12/24v & +/- ground so not that hard to find and you can then get a new sticker - think some of the stickers not right.
    However IMHO - the correct original ones will not have "In/Out" on them but "Ein? /Aus (made in Germany by Pierburg) - a bit more of a challenge to find - the odd used one around on epay. Keep looking long enough you might get lucky with NOS - Keep an eye on 356 Registry site also. Two in the last year or so that I know of. Its a daily ritual habit. (I know I have a problem)
    Also mentioned somewhere on the forum about the correct Bosch part number for coil - then of course there is the date code.....
    Bosch codes for 1965 501-512
    Membership #3255
    301022
    revivem.co.nz
    May 2014
    Netherlands
    Txs Ivan! Indeed black top NOK.
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    if they're working why not refurbish both?
    May 2014
    Netherlands
    Ulli, I have none to refurbish, but would of course buy an original used one if I can find that.
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
