Thread: Engine swap oil cooler adaptor needed
    Mar 2013
    Surrey, UK
    Hi,
    i have a 79 SC engine installed in my 70T. The engine runs fine, but it leaks oil. I've now made 3 attempts to fix it but it still leaks.
    I will change the oil cooler this weekend, but i also plan to change the oil tank to engine oil cooler oil line.
    The problem is that i have a 70T oil tank with a screw fit hose and a push fit hose on the 79 oil cooler.
    Does anyone know if there is someone who makes an adaptor for this or who can make a custom oil hose? I would rather not change the oil tank to the later style one.
    Here are some pics of either end of the oil line. I have joined the old and new style line, but i think that's leaking too, hence the need for a custom solution.
    Many thanks
    Paul
    May 2005
    Oroville, CA
    Can't you use an early cooler to match your car?
    H
    Mar 2013
    Surrey, UK
    Yes, i could do that, i just don't have a useable early cooler handy. My car is in Switzerland and my original engine with the cooler is in storage in the UK.
    May 2005
    Oroville, CA
    I honestly don't see an easier way than to install an early cooler.
    I've spent far more on a smaller leak....
    H
    mad scientist
    Apr 2007
    Austin, TX
    Contact Len at Automotive Engineering. He makes custom adapter lines exactly for this purpose.
    1971 911T SWT - Sun and Fun Machine
    1972 911T - "Minne" painted and undergoing assembly.
    Mar 2013
    Surrey, UK
    Quote Originally Posted by jpnovak View Post
    Many thanks jpnovak, i've just ordered an adapotor from len@autosportengineering.com. Hopefully that will sort that leak at least.
    Paul
