Thread: 2.0S cam timing question / confusion
    Jul 2008
    near Ottawa, ON,canada
    the car is in the final stage , engine rebuild , all part new/ rebuilt
    now to cam timing , I have wayne books and seen video but one part still has me confused
    the switch between sides to side and the turn , no turn is confused in all video or methods
    #1 and 4 rocker or installed and adjusted
    help me fill the blanks
    1- you set the crank at Z1 , and cam with dot / keyway on top ( that's 1 @ TDC spark)
    2- you rotate 1 turn CW back to Z1 , you are now at TDC overlap
    3- lock crank , rotate cam CW or CCW until valve is 5.2 mm down ( its a 68S) , right side is done ,
    4- you turn 2 turns and you check that you still have 5.2 mm , at TDC overlap
    5- that's where I get confused, where is # 4 , , its a TDC ,, but is it tdc spark or TDC overlap
    6- if its a TDC spark , then you install the gauge, zero it , rotate 1 turn , ( now your at TDC overlap )
    7- adjust to 5.2 , rotate 2 turn to check and your done
    or did I miss something
    thanks
    now on the road 914-6
    now in the shop for concourse resto 11850275 S SWT
    daily driver B8 S4 stage 2
    Feb 2007
    San Diego
    Each side works opposite of the other at TDC. So while one side is opening the valve then the other side is closed. So while you are at TDC overlap on #1 you are at TDC spark on #4. Get the #1 side timed and then go to the other side and time it, if you do it wrong then you will know as the valves won't adjust properly. Sometime you just need to go through the motions a few times to get the hang of it, if you mess up you can always go back. It can get confusing, especially reading the book over and over, but getting the feel for it you will know when it is right. If you put more rockers in and they don't stay in adjustment then you did the timing wrong.
    Jul 2008
    Thanks for the quick reply
    That explanation should be in all the books
