Thread: replacement panel quality?
    Senior Member tcsracing1's Avatar
    Nov 2015
    Somewhere in a galaxy far, far away....
    In the world of replacement panels for longhood restoration, who has the best quality panels on the market?
    www.tcspeed.com
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by tcsracing1 View Post
    there is not so much choice anyway.originalos,dansk/JP or restoration design
    i usually go for originalos and cut outs from donor cars...but let us know what you need..
    Oct 2010
    Florida
    Cut outs from an original car may be the best solution. It's not always possible though. I used Restoration Design in Canada and the shop never complained about the quality of the fit. So it had to be good.
    Name:  911 Rear Seat Pan Repair.jpg
    Richard Newton
    Car Tech Things
    Senior Member GT3Racerich's Avatar
    Oct 2005
    Bucks Co. PA & L.I. NY
    Who makes the sheet metal (body panels, bumpers, etc.) that Porsche sells?
    Rich
    mad scientist
    Apr 2007
    Austin, TX
    Most of the Porsche P/N panels That I have been using on my 72 have a Dansk number on them. The fit is all over the place. In some cases the Dansk is better than Restoration Design and in others its the opposite. I have purchased a few of the same panel from both suppliers for comparison. Its the little details. For example, how sharp and crisp are the edge corners and flanges. Are then sharp 90 deg or are they lazy stampings with a radius. It makes a difference. However, metal is malleable. You can almost always get it to the shape you want. Sometimes it just takes a BFH and other tools.
    Yes, factory original panels or cutouts from a donor car will always fit better than aftermarket. However, these types of panels are not easy to find. So, you eradicate the rust the best way you can and move on.
    1971 911T SWT - Sun and Fun Machine
    1972 911T - "Minne" painted and undergoing assembly.
