Thread: Need help in identifying 65-66 seats
    Apr 2011
    N.Calif., south of SF
    Looking for advice on how to correctly identify 1965-1966 front seats.
    My 65/66 has later seats in it (1970-71?) and I want to replace them with period correct seats.
    Are there certain features that would identify the 65-66 seats. As say compared to 1967 seats?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Aug 2009
    SF Bay Area
    Quote Originally Posted by Haasman View Post
    Not really, except for date stamps on the hinges if they haven't been rubbed off.
    Ciao
    Jim
    Nov 2002
    San Dimas, CA
    I'm afraid I can only give you some basics. First, a '67 seat is the same as a mid/late-'65 or '66 seat. But, there are two different 1965 seats. I'm guessing your car's from late 1965 since you asked about "1965-1966 front seats."
    VERY EARLY SEATS
    The very first '65s--up to chassis 301045 (~April-May 1965)--had one seat (901.521.001.20/901.521.002.20) and cars from 301046 through the end of '67 had another (901.521.001.21/901.521.002.22).
    I think the big visible difference is that the early seats had six pleats in the insert and the later seat had five. Here's a photo from an early brochure showing a 6 pleat seat:
    Name:  April 65 Page 03_Numbered.jpg
    MID-'65 THROUGH '67 SEATS
    The big change in the seats was the headrest. Up through 1967 Porsche headrests were attached to the back of the seat:
    If the seats weren't fitted with headrests there would be no brackets or holes for headrests.
    SEATS FROM 1968-ON
    After 1968 the headrests had prongs that went into the top of the seat:
    The key point here is that all '68-on seats have the two holes on the top of the seatback (according to Brett Johnson's The (early) 911 & 912 Porsche -- A Restorer’s Guide to Authenticity).
    So, 911 seats without holes for a headrest and with five pleats should be correct for your car.
    Here's a photo of the seats in my car (301382 so these are the early/mid-1965 on seats):
    That's the best houndstooth I could get in 1997 but it's not a perfect match.
    Be aware that 356C (and probably 356B) seats look the same but won't fit. The rails are a different distance apart.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Apr 2011
    Thanks you gents. Good info. The chassis these seats are to be going into is #302580
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Mar 2012
    Scotland
    Ciao
    Jim
    What do you make of this Jim. I dissembled may Sept '65 car hinges yesterday. Found these markings. They are original to the car, five pleat perforated black leatherette, all as they should be but that hinge date??? But smudged but ...
    There are so many mysteries in this car!!!
    Aug 2009
    SF Bay Area
    Not sure what to make of the date stamp, if it is actually a date stamp. Looking at your hinge tells me that your car is RHD, though.
    Jim
