Thread: 911R style muffler availability
    Does anybody know if a 911R style muffler (dual tail pipes spaced around 30 inches apart) is available that bolts to standard heat exchangers? The Dansk one sold by multiple suppliers is compatible using only a header system and pipes that connect the headers to the round inlet flanges of the muffler. The pipes bolt to the header and are either press-fit or clamped to the muffler flanges.
    Funny you should ask that.. Just started making some
    (ours are SS, though - based on Dansk SS mufflers.)
    keith
    '75 RS/RSR-look | '73 CB750 | '70 TD250B
    r gruppe # 436
    Patrick Motorsports also sells one with 29" or so spacing.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Oct 2010
    Florida
    They're really easy to make. Also very cheap to make.
    Name:  911 Exhaust 2.jpg
    Name:  911 Exhaust 1.jpg
    I got the pipes from Advance Auto and my fabricator made the end caps from some old photos. The total expanse was less than $50.00.
    Richard Newton
    Car Tech Stuff
    We make them to match up to our 911R Rear Bumpers. (We made this one to suit a narrow fender as the owner didn't want R Rear Flares.)
    We also have 911R Chrome Plated Hinges back in stock.
    There are Mild Steel, Brazed, Plated and use a clevis pin and cotter as the hinge instead of a screw and a nut.
    We supply them will all of the hardware to fit along with a drawing of the location and a sticker as a drill guide.
    Chris, I'll get in touch with you early in the week about a couple pair of hinges (they're the only ones I'd buy, personally - fwiw)
    keith
    r gruppe # 436
