Results 1 to 9 of 9
Thread: Windshield Wiper Switch
    I was out driving my '72 in the rain this weekend, and was using the wipers on low speed. Then, the rain let up, and I started using the "washer" setting to mimic intermittent wipers. All was fine for a while. Suddenly, wipers were going at high speed, pausing a bit, then going again. Turning the wiper switch did not stop the wipers. They even continued to run after I turned off the ignition! Finally, after cycling the ignition switch, they stopped, but parked about 30 degrees too high.
    Did my switch just fail?
    Thanks in advance.
    Mike
    Mike Hinton
    Early S Member 1728
    1972 911-T Aubergine
    1987 Carrera Granite Green
    Aug 2009
    SF Bay Area
    Most likely.
    Lucky for you, they are niether rare nor expensive.
    They are easy to change, too.
    Jim
    I'm assuming that you were kidding when you said that the part was neither rare, nor expensive...
    Mike Hinton
    Early S Member 1728
    Senior Member majordad's Avatar
    Dec 2012
    Cork , Ireland
    Exactly the same happened to mine in my 2.4 S 1972. I'd to buy a new unit, found on mitellie.de or similiar site. The only way to stop it was to pull the fuse.
    I suspect an ingenious person might be able to repair it.
    Oct 2011
    The land of fruits and Nuts
    Quote Originally Posted by mikehinton View Post
    He was serious. It appears he's got about 10 sitting right there ready for ya
    Porsche taste on a Volkswagen budget...
    Aug 2009
    SF Bay Area
    No, I was not kidding. The pile of switches shown is just the tip of the ice berg. Call me and I'll send you one for a reasonable/realistic price. I don't live in the desert, either.
    Jim
    Hi Jim:
    Was out of internet range for a while. Would definitely be interested if you have one. I live in the Napa Valley.
    mike
    Mike Hinton
    Early S Member 1728
    Aug 2009
    SF Bay Area
    Hi Jim:
    mike
    Mike
    Stop by Rombauer and pick up a bottle of Chardonnay, place it on my counter and you can take your pick of 20 or so wiper switches, or you can just bring $50.00.
    Jim
    PS: Wait till the first Saturday in Dec (Dec 3). Come in and you will be joined by a 100 or so like minded early 911 fanatics, eating doughnuts and drinking coffee.
    Thanks, Jim. I'll see you then!
    Mike
    Mike Hinton
    Early S Member 1728
