Results 1 to 1 of 1
Thread: later door handle plastic insert
    The Netherlands
    Dear all,
    I have a set of later (from when on?) chromed exterior door handles but to make them work I need a plastic insert that does not allow the key on the lock cylinder to rotate 360 degrees, but around 180 degrees as with the our area door handles (69-76?). Early version door handles do have a 180 recess in the bore, while the later ones none hence the plastic insert. Pictures will make it a bit easier to understand. So where can I get these plastic, PEEK or other material inserts?
    Cees
