Thread: 2.7 RS Spec w Early S MFI Value
    May 2014
    Canada
    Hello,
    I am looking for a little help on approximate value as I am looking at selling (or trading). I have a 2.7 RS Spec engine with Early S MFI (Soup to Nuts). The MFI pump was converted to 019. The case is 911/51 (72/73).
    Any help would be greatly appreciated !
    Oct 2005
    wash dc/ los angeles ca
    I am just completing a very similar build albeit on a 7R case , yours being a 911/51 it could be .a 5R or even 4R
    this has little bearing however some are looking for the later numeric case as it is I've been led to believe stronger.
    if you have RS components, heads, pistons , injection etc and rebuilt or low mile I would expect a value in the
    $17.5k to $25k
    i probably wouldn't part with mine for any less and mine has factory original S injection as well , this is bearing in mind a real 911/83 is now costing $35-$50k and up ..
    i'm sure others may have additional info Bert
    May 2014
    Canada
    Thank you Bert. I appreciate you taking the time to give me your thoughts.
    Cheers
