Results 1 to 7 of 7
Thread: attachment orange tubes for rear window heating
    Senior Member pss's Avatar
    May 2014
    Netherlands
    I bought these tubes but do not know how these were fixed to the metal on either end. They came with 2 white and thin tie-wraps, but assume that is not correct for 1965.
    Also, did the hot air directly flow thru these or was there an inner tube?
    Name:  organge tube rear window heating.jpg
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    964 RS clone (one of many)
    964 Targa original Dutch police car (one of 45)
    964 Turbo 3.6 (one of 1450)
    993 S Vesuvio (one of 250)
    Sep 2013
    Kalamazoo, MI
    My 67 is attached with those white plastic tie straps. Nothing inside the tube.
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by pss View Post
    hope it`s T&B straps that came with your order.
    no inner tube
    http://www.early911sregistry.org/for...am-heater-tube
    May 2014
    Netherlands
    Gosh, all the important things in life seem to have been invented already back then......turbo, cars with electrical wheelhub engines, 4 wheel steering, and now also tie wraps......What have we been doing lately?
    Txs guys, also Jimmy for yr mail.
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    Rear window defroster tubes
    First a photo (1967 911S original) showing the top section of the orange defrost tube with the "T & B Ty-Rap" holding it in place. If you have a 911R, the same "T & B Ty-Rap" was used on the flex oil lines in the L/R fender housing prior to the oil tank...
    Ernie W
    member of Early 911S Registry
    I have been looking for some tubes, where did you get the one in the picture?
    Regards,
    Dan
    MBR #2637
    AKA boschdog
    1968 911 Normal Coupe
    Houston, Texas
    May 2014
    Netherlands
    txs Ernie.
    I got them from Sierra Madre
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
